Anybody know my options when it comes to a lost key? Im about 95% sure I lost my key for my 2007 ZX14. What can I do now to fix this problem? Ive never lost a key before.
Thanks in advance
Created on: 02/04/17 11:10 PM
07ZX1352
RE: LOST KEYS
02/04/17 11:39 PM
You can get replacement keys from a dealer. If you have any of the original information they came with a tag containing the code. If you lost the code, the dealer should be able to get the ocde somehow to create a key. You might be required to prove ownership and that sort of thing, not sure.
Hopefully your bike doesn't have an immobilizer, minimally the keys are very expensive.
KoflaOlivieri
RE: LOST KEYS
02/05/17 2:35 PM
I have a 2010 Zx14, lost my bike's tags key code and replacement key. So before losing my original key I ordered (2) blank keys from Ebay for $8.00 dollars each, took it to a hardware store in my neighborhood, and had keys made for $2.00 dollars each.
Have you removed the ignition switch yet? If you are unable to obtain the key code from the ignition switch, you can probably get a used set of ignition switch, tank and seat lock on Ebay. Here is one on Ebay for $78.00 dollars.... Good luck!
* Last updated by: KoflaOlivieri on 12/15/2017 @ 7:58 PM *
07ZX1352
07ZX1352
RE: LOST KEYS
02/07/17 11:41 AM
1. I rode the bike home and is in the garage.
2. I have this universal aging problem called, 'don't get old' is the memory loss.
3. I better re-step my steps because the key has no legs as if it walked out the front door.
a. I had to tow my bike home on a hook; I locked the front end.
b. I have this scenario because the fuck if I know where the bike is with said info.
c. I had to add this variable, because you just never know on the net.
One; I better look in the clothes hamper and see if it dropped out I keep checking pants and jacket the last 30 times.
Two; I have two keys and an aluminum fob with code stamped in it.
Three; I never took the other key or the code fob off so yeah, that's what's missing is all of it.
Year Fucked:
I. I have a chip in my key so no locksmith will help.
II. I have to change the whole shebang is... only a parts page knows for sure.
III. I might have to find a dealer to reset the ECU for the k-steal system, since the bike is an unknown from what country and all that.
Nightmare
RE: LOST KEYS
02/08/17 9:07 AM
You'll want to use something LIKE this:
http://www.princessauto.com/en/detail/2-pc-vehicle-dollies/A-p8535924e
Getting it on the back of a truck would be a challenge a low trailer would be easier and I cringe at the thought of a tow truck... :(
07ZX1352
